DTMF not transmitting on Skype
Discussion in '3CX Phone System - General' started by rkarem, Dec 14, 2010.
  1. rkarem
    Jul 4, 2009
    9
    I have a problem on Skype where tones are not being received after connection with a party. This incudes anyone with a tone selectable options such as banks, dictation systems and answering machines. The initial dial up is successful but the receiving phone does not receive the tones.
    I am using version 8 and Yealink T20/ T28 series phones.
    Thanks.
  2. rkarem
    Jul 4, 2009
    9
    As no one has responded to this post I thought I would post the answer, which I found afer some searching. The yealink phone Account => Advanced Settinggs -> DTMF Type should be set to "INBAND"
  3. shuster1
    Nov 10, 2010
    For the record.
    This also happens with other Voip providers. I am using Cisco SPA303 Phones, I had to set the DTMF Tx to Inband+INFO.
    JS
  4. leejor
    11,119
    329
    And not just VoIP providers/Skype, this can happen with PSTN Gateways as well. The DTMF method, has to "match up".
