DTMF on IVR not working
Discussion in '3CX Phone System - General' started by minnesota, Apr 18, 2017.
  1. minnesota
    Nov 24, 2014
    43
    Hello. We are experiencing intermittent issues with customers selecting an option on the IVR. We only have two options: 1 and 2. When I call and listen to the prompts and select either option, nothing happens. It doesn't respond and then my call ends after the preset time I have set in the IVR.
    Some customers are making it through fine but others are not and have tried 4 calls. I tried 3 times from my cellphone and haven't gotten it to work yet today. It is not happenings every call and we've made no major changes that might cause an issue. We're running v15 SP5 and also rebooted our Linux server as well. Firewall passes all checks.
    Any ideas? Thank you
    11,283
    360
    What type of trunking are you using? If more than one type, is there any difference?
    If you dial into the IVR from a local extension, does it work correctly?
    #2 leejor, Apr 19, 2017
  3. minnesota
    Nov 24, 2014
    43
    We use Vitelity for our incoming calls.
    I tried dialing our IVR from 3CX app on my phone and it works fine using that. So far it's only calls from a normal cell phone line for example. It still doesn't work with my cellphone line this evening.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    @minnesota
    I have sent you a p.m to send me some files so we can take a better look at your issue.
  5. leejor
    11,283
    360
    Probably something in conjunction with the short duration DTMF tones sent from a mobile.
