DTMF on Siemens Voip phone
Discussion in '3CX Phone System - General' started by jphe1, Jan 4, 2007.
  1. jphe1
    Jan 2, 2007
    I just bought a Siemens Gigaset C450IP DECT phone, all is working well, but when I try to access the voicemail box, the system isn't responding at all to the keys I press on my phone (extension number etc.) I also can't find anything in the phone configuration that could explain the problem.
    With the softphones I don't have that problem.
    Does anyone have a solution??
    Thanks in advance!
  2. Watashi_FR
    Dec 5, 2006
    63
    A quote from a different topic:
  3. newtristan
    Mar 25, 2007
    10
    I found this in C450ip menu:
    DTMF pour les connexions VoIP
    Envoyer les param
  4. Anonymous
    Anonymous Guest
    It might actually the media server :).
    Here is to go about:
    In advanced options select "bind to media server" de-select "device is external".
    Henk.
