DTMF Question
Discussion in '3CX Phone System - General' started by Mbacicc, Jan 13, 2008.
  1. Mbacicc
    Jan 1, 2008
    8
    What does it mean?
    It doesn't recognize inputs
    Mbacicc
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    666
    5
    I guess you 3CX box trying to call some VOIP provider that cannot support DTMF using RTP payload (RFC2833).
  3. LORD ORION
    Jul 23, 2007
    39
    You can see RTP payload events in wireshark. So check to see if they are there.
    Basically, trace a call you used DTMF with wireshark and then
    1) Statistics -> VOIP Calls
    2) Graph
    If the events are there and not being recieved, trying increasing MTU in small increments.
