DTMF question
Discussion in '3CX Phone System - General' started by cparman, Oct 6, 2014.
  1. cparman
    Oct 6, 2014
    Hello All,
    Is DTMF configurable from the point of changing to "inband DTMF". Also, is the "payload type" configurable when Out of Band is enabled?
    10,374
    231
    That all depends on the type of VoIP device(s) you are dealing with and the options they offer. You may want to elaborate on what you are trying to accomplish.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    On the 3CX system itself......no. But as Leejor indicated, yes...depending upon the end devices offerings.
