DTMF? Question
Discussion in '3CX Phone System - General' started by sanderweijers, Mar 16, 2009.
  1. sanderweijers
    Feb 9, 2009
    Good afternoon all,
    I've got a question/problem, I think regarding DTMF.
    The configuration:
    3CX v7.04.4744.0 PBX
    Patton M-ATA (extention 282) connected to an analogue Home Control Box
    Granstream, Snom and Linksys SIP phones.
    Direct lines using a VoIP provider.
    The problem:
    When I call a Home Control Box (HCB) with a SIP phone (Linksys, Snom and Grandstream), the call is awnsered and I can sent DTMF tones to enter the pin for the HCB. Everything fine.
    When I configure a line from a VOIP provider to connect directly to the extention of the HCB, the call is connected and I can hear the menu speaking, but the PIN I have to enter is not accepted. It acts like it does not receive any numbers.
    When I configure the line to be awnsered by a 3CX Digital Receptionist, I can make a choise without any problem.
    Allready tried to add the extention to a digital recptionist, but this also does nog make any differance.
    The logfile (verbose with **** at the telephone numbers):
    14:28:09.425 [CM503008]: Call(3154): Call is terminated
    14:27:56.910 [CM504001]: Ext.282: new contact is registered. Contact(s): [sip:282@172.28.44.104:5060/282]
    14:27:50.941 [MS211000] C:3154.1: 83.98.222.254:17132 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    14:27:41.706 [CM503007]: Call(3154): Device joined: sip:282@172.28.44.104:5060
    14:27:41.691 [CM503007]: Call(3154): Device joined: sip:83.98.222.20:5061
    14:27:39.097 [CM505001]: Ext.282: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton Smartlink MATA ] Transport: [sip:10.10.11.100:5060]
    14:27:39.081 [CM503002]: Call(3154): Alerting sip:282@172.28.44.104:5060
    14:27:38.878 [CM503004]: Call(3154): Calling: Ext:Ext.282@[Dev:sip:282@172.28.44.104:5060]
    14:27:38.878 [CM503010]: Making route(s) to
    14:27:38.878 [CM505003]: Provider:[Tritel-****] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] Transport: [sip:10.10.11.100:5060]
    14:27:38.878 [CM503001]: Call(3154): Incoming call from ****@(Ln.10003@Tritel-****) to
    14:27:38.722 [CM503012]: Inbound office hours rule (unnamed) for 10003 forwards to DN:282
    Hopefully someone can help us out!!
    Cheers,
    Sander
    10,362
    227
    It sound like the HBC requires audio DTMF (In-Band) and won't accept RFC2833. From the looks of the logs, for what ever reason, in-band has been disabled. Since the calls are coming from a VoIP provider I'm assuming that they aren't sending In-band DTMF and only RFC2833 which would normally be decoded and then a DTMF tone generated at the receiving end. Perhaps 3CX doesn't do this when a call is extended to an extension. If you place a call via your VoIP provider, come into the board and answer the extension, can you hear DTMF tones sent from the callers phone? If you can then perhaps they are too short a duration. i know I've had problems with DTMF in the past, not 3CX, when any codec with a lower bit rate than G711A or U has been used.
  3. sanderweijers
    Feb 9, 2009
    Hi Leejor,
    Thanks for your reply. I've been testing with your tips and some other things I found in another post.
    I discovered that the problem had to be in the Patton, since a Linksys gateway (SPA3102) was working fine!
    After some struggling, I found out that the RTP port values were not defined. After setting these, it finally worked.
    Current config (maybe useful for others):
    Send DTMF Events: In-Band & OOB
    RFC2883 payload value: 96
    Regenerate OOB DTMF Tone: Enabled
    RTP Port Min: 16384
    RTP Port Max: 16482
    Sander
