DTMF SETTING FOR 3CX
Discussion in '3CX Phone System - General' started by tranceaddict, Apr 7, 2009.
  1. tranceaddict
    Jan 5, 2009
    17
    I have several DTMF options in my phone setup?
    What are the correct settings for 3CX. The options are:
    RFC2833
    Inband DTMF
    Send DTMF SIP info
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    RFC2833
  3. aabbcc
    Oct 3, 2008
    5
    RFC2833
    Inband DTMF
    Send DTMF SIP info
    Anyone knows what the difference is? Can I select all of them?
  4. leejor
    10,853
    299
    Have a look at this site for a detailed explanation....http://www.faqs.org/rfcs/rfc2833.html
    in a nutshell...You can send the DTMF "In-Band" as audio from one end to the other or the SIP device can decode the tones and then send SIP packets to the far end where the tones are regenerated. In-band has a lot of trouble and in fact may not work at all when you choose to use the low bit rate encoders.
