dtmf tone length
Discussion in 'Windows' started by michalakis, Jan 23, 2013.
  1. michalakis
    Jan 23, 2013
    is there any way/setting to change the dtmf tone length?
    I am not able to send my PIN to access external line (to asterisk) - there is no way whatever dtmf setting i have entered.
    I found somewhere in the net that changing dtmf tone length will be the solution - how can i do that in 3cxphone?
    thanks!
    michalakis
