DTMF Tones Iphone/Mac Issues
Discussion in 'Call Flow Designer' started by agesen, May 30, 2017.
  1. agesen
    Oct 17, 2016
    18
    Hi All
    Anyone having issues with DTMF tones being recognized correctly in CFD?
    Regards Nanna
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,449
    115
    Hi Nanna,
    Please check if you have the same issue with a standard Digital Receptionist as well. That will tell you if the issue is related to the CFD app or maybe a problem with the protocol used by the phone to send the DTMF digits. Also, please check if this happens always, or just when calling from specific extensions, or for calls coming from a SIP Trunk... For DTMF there are 3 protocols that can be used: RFC-2833 (recommended), SIP-INFO and in-band audio. Depending on the method used by the calling phone you might experience problems with DTMF detection on the CFD side.
    Kind regards.
  3. agesen
    Oct 17, 2016
    18
    Hi Ernesto
    I found out this is not related to CFD.
    I was testing our new cfd design from the 3CX web client, and the problem is with IP desktop phones, Win/mac clients.
    Regards Nanna
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Hi Nanna
    If I understood correctly, you're trying to send DTMFs from the webclient? This will not work, currently there is no support for it.
  5. agesen
    Oct 17, 2016
    18
    Hi Vali
    Yes that's what I was trying :)
