DTMF tones
Discussion in 'Windows' started by GarethT, Aug 12, 2008.
  1. GarethT
    Aug 12, 2008
    7
    when using the soft client, I can't send DTMF tones to a remote system; you know, the "press 2 for.." type of thing? Digital operator as 3CX call it.
    Is there a way to configure this? Without it, it is useless as an Enterprise system.
    Can't find anything in the manual at all. I need a 3CXpert...
  2. GarethT
    Aug 12, 2008
    7
    latest download of 3CX and the softphone, and all the DTMF boxes are ticked. I don't hear any tones when I press a key, and the remopte system does not register any as being received.
    Gareth
  3. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    what if your try the Xlite free version....this typically works well also.
  4. tekknow
    Oct 3, 2008
    29
    I posted this about 12 hours ago and now ity is GONE
    Here it is again
    id you ask inphonex what DTMF they support?
    There are three types
    1) Inband , works only with g711u or G711a
    2) out if Band RFC2833 otherwise known as AVT
    3) out of Band Info
    You need to support the format that Inphonex uses all the way through the chain as I do not know if 3cx translates DTMF
    I do not see DTMF options in 3cx so I ASSUME that it passes whatever you send.
    Also you need not HEAR DTMF tones as in the case they are sent out of band
  5. Craigie
    Aug 20, 2008
    5
    Hey, we are having the same problem when we use the 3CX softphone. We tried the xlite sip and it works fine with our 3cx server, but I would prefer if I could keep everything in the 3CX family :) I checked all of the DTMF settings and all boxes are checked. Any other ideas?
    thanks,Craig
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CX VoIP Client will send DTMFs as requested in configuration (you can use any combinations). If you request SIPINFO, RFC2833 and INBAND simultaneously then it may confuse external IVR. X-lite (by default) sends it only as RFC 2833. Please try to configure 3CX VoIP Client to use ONLY RFC2833 transport for DTMF and you should get the same functionality. If it is not as declared above - it is "the bug"
    Thanks for your feedback
  7. Craigie
    Aug 20, 2008
    5
    Stepan,
    Sorry, I didnt see this response until today, when I was looking for information on the V7 client installation problem. I wanted to tell you that I tried your suggestion and boom, it worked! Thank you so much!
    I really appriciate what a great product you guys have developed:)
    Again, thanks...
    Craig
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    Now your turn, you should provide a bug report! ;)
    Thanks a lot for such high appreciation of our work!
