DTMF with Webclient
Discussion in 'Ideas' started by Nicolas Borowy, Oct 5, 2017.
DTMF with Webclient 4.9 5 8votes
4.9/5, 8 votes
  1. Nicolas Borowy
    Aug 17, 2017
    8
    We have to install the webclient on RDS but we want to use the desktop PC to install the softphone.
    DTMF don't work with webclient, it's critical.
    Please, is it possible to implement this.
    Thank's
    Said CHAKIR likes this.
  2. Nicolas Borowy
    Aug 17, 2017
    8
    Solution please...
  3. Silly English Kniggit
    Sep 13, 2017
    220
    89
    If I understand you correctly - you're using the web client on RDS to trigger the soft phone on the desktop PC.... so why not enter the DTMF on the soft phone - which is part of the call, not a remote control (which is what the web client is)?
  4. rvoosterhout
    May 24, 2017
    52
    This would be useful. We call a lot of company's who use an auto attendant. When we want to send a DTMF key tone for a choice, we have to open the pc client because we can't send DTMF through the webclient.
    Nicolas Borowy likes this.
  5. itce
    Aug 17, 2016
    12
