DTMF, Yealink T38g and NTE-101
Discussion in '3CX Phone System - General' started by Mullenlaw, Feb 13, 2012.
  1. Mullenlaw
    Apr 13, 2011
    53
    I have a bunch of T38 phones and for the most part the DTMF works.
    But there are a few situations where the other side says "invalid".
    I've messed with all the setting options / combinations.
    What should it be set to?
    Our provider says we should be using NTE-101 inband.
    I assume that is Inband with a payload of 101, but not sure what the NTE means
    and what the selection for "How to INFO DTMF" should be for yealink.
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    NTE stands for Named Telephone Events and is documented in RFC 2833, so if your provider specified NTE with 101 payload you should use RFC 2833 not inband. So choose DTMF types RFC2833 and How to INFO DTMS choose DTMF-Relay to enable NTE mechanism. If you want to read more about DTMF and NTE mechanism look here: http://www.ietf.org/rfc/rfc2833.txt
