DTMF
Discussion in '3CX Phone System - General' started by POTI, May 29, 2010.
  1. POTI
    May 19, 2010
    7
    When I enter my PIN from inside it works 100% but when I enter my PIN over an outside thru skype call I get constant failures. Is there any workaround to get the DTMF tones working properly?
    Phil
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,500
    67
    Hi Phil
    I'm not sure I properly understand the "inside"/"outside" meanings. All I can tell you is that Skype client doesn't process (pass) DTMF coming from PSTN, say mobile phones. Therefore, gateway either.
    Regards
    vali
