DTMF
Discussion in '3CX Phone System - General' started by Chrisvdl, Aug 19, 2008.
  1. Chrisvdl
    Aug 5, 2008
    Hey guys
    How do I configure the DTMF setting for 3cx
    Phoning in from a land line now works, for example,
    if i phone in and "press one for sales and two for support" it then works
    But when phoning in from a cellphone it doesnt work, and the only problem that i can think of is the dtmf
    Can anyone please set some light on my situation
    Thanks guys
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    The line you are dialing to, form your mobile, is it a line set as a PSTN line on the PABX lines or is it a VOIP line?
    regards
