Dual Network Cards - how to set
Discussion in '3CX Phone System - General' started by keith.bucknall, Aug 21, 2007.
  1. keith.bucknall
    Feb 22, 2007
    38
    Guys,
    How do i force 3CX to use 1 of the 2 network cards i havek.
    Keith
  2. Anonymous
    Anonymous Guest
    Do a search.
    In principle it is like this.
    3CX uses a web server, this web server will listen to all the IP's and specified ports.
    There are some config files you can change (Ill have to come back to you on that but they are discussed on the forum).
    If you can get away with one network card in the box I would do that.
    It would be nice if 3CX could include a function to bind the app to one network card, but not sure if they will.
  3. keith.bucknall
    Feb 22, 2007
    38
    thanks but i need to in there and thought it would be better routing the traffic on its own deadicated NIC.
