during call -- other IVR's cannot detect dialed digits
Discussion in '3CX Phone System - General' started by dbergsma, Jan 5, 2009.
  1. dbergsma
    Oct 27, 2008
    39
    Hi Folks,
    during external call to someone's IVR system, it asks 'press 1 for english' -- and, even if I press really, really hard :) -- the other system does not pick up the dialed digit.
    Counterindicators - Internally, the 3cx voicemail works fine with keypress.
    Configuration: v7, linksys spa942 with dial plan of [x*]. as specified.
    The only outbound plan that I have is 'if it starts with a 9, make it outbound' and strip 1st digit.
    Anyhelp would be greatly appreciated.
    Cheers
    Dean.
    Ps: v7 -- is a big improvement -- kudos to the team.
  2. mattscott
    Dec 21, 2008
    12
    Dean,
    Are you using a VOIP provider or some kind of gateway? It sounds like maybe the phone's DTMF settings don't match what your VOIP provider is expecting. I have worked with a VOIP service before that requires your DTMF settings to be set to in-band (i.e. the touch tones are sent as part of the audio stream). If you set DTMF to out-of-band it behaves just like you describe. The other end never hears your button pushes.
    I am not familiar with that particular phone so I don't know what options you have. Just thought I'd share the similar experience I have had.
    Good luck!
    Matt
  3. FoxhallVoIP
    Sep 10, 2008
    12
    I've had to change the DTMF settings on the SPA9xx phones I've installed.
    At the bottom of each 'Ext' page [below the codec settings], you'll see a 'DTMF Tx Method:' setting. This defaults to 'Auto'. Change this setting to 'InBand' and all should start to happen how you expect it to.
  4. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    I had to do the same thing. I would imagine this will work for your solution.
