DVR of all calls in case you press record late in the call
Discussion in 'Ideas' started by mmancini, Mar 10, 2016.
  1. mmancini
    Sep 28, 2012
    6
    How about an option to record ALL calls so that if you hit record half way through the call then it has the ability to record from the start of the call. If they hang up then that recording is deleted if they never hit record. Another system has it and we got grief for not having it
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    3CX had the ability, by extension, to turn on Record All Calls.
    Allen
