Dymanic IP Address for Mobile phone
Discussion in '3CX Phone System - General' started by Alliedbs, Jul 15, 2009.
  1. Alliedbs
    May 29, 2009
    19
    Can i use DYNDNS service for the mobile phone software setup??? Which are the thing that i need to take note?? Router need to port forward to??? Pls Advise. THks...
    10,757
    286
    You would normally use the DDNS service on the router at the 3CX end. The "mobile" phone, (remote extension) need to know where to go to register with 3cx if you have a public IP that can change. Setup the mobile set to use STUN and 3CX will know where it is and what port it is using behind a router. If the mobile set is getting a public IP, then you don't need to use STUN.
