Dynamic audio path
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Dec 9, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I noticed in the logs that the dynamic audio is automatically being appended to the working directory. So that means any dynamic audio I use must be within the working directory. I want to reference a path elsewhere on the system.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Currently you can use a relative path to reference a file somewhere else. For example create an expression that returns "..\..\..\Somefolder\Somefile.wav".
    But I think it would be better to let the user creating an expression to the full path. We'll consider this as a change for the next release we're working on.
    Thanks for your feedback!
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    OK, that's a good workaround for the file.
    I'm planning to just use a copy file code component I made to copy the files to the working directory, and then grabbing them as dynamic audio.
    As for the relative path, one problem is that I think the number of directories back to the c:\root is differnt for XP and win7, so you couldn't deploy the same VAD on those machines without changing the depth of the relative path.
    Maybe I'm wrong, I'll go count the folder depth.
  4. VAD_Support
    Aug 6, 2009
    690
    Yes, maybe you're right. Anyway we'll see if we can change that, so you can create an expression to use the full path.
