dynamic audio
Discussion in 'CRM / Helpdesk / App Integration' started by kilo13, Sep 8, 2011.
  1. kilo13
    Dec 22, 2010
    14
    not sure but on the prompt there is no expression builder. So I am not sure whether putting copying a variable into the field works with the resulted string but I get an error message of no audio file found or invalid characters.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    In first place be sure to have installed 3CX Voice Application Designer, Build 3679.
    Then, you need to add a prompt of type DynamicAudioFilePrompt (click on the arrow on the right). Take a look at the screenshot in this blog article from the Spanish blog:
    http://www.3cx.es/blog/vad-archivos-dinamicos/
    That article will be translated to English soon.
    Regards,
