Dynamic DNS for 3CX
Discussion in '3CX Phone System - General' started by gordontor, Sep 7, 2013.
  1. gordontor
    Jul 6, 2013
    14
    I can register my atas and dial out using the dynamic DNS xxxxx.no-ip.com or the xx.xx.xx.xx IP address. Now I want to use a new no-ip host. With the no-ip.info, myvpn.com and any of the no-ip free hostnames, I can register my ATA and receive calls, but can not dial out. It shows "Call failed. 403 Forbidden". I tried many other free DDNS and got the same result. Which dynamic DNS do you use?
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I don't. Get a static address and use static DNS.
    That being said, the PBX is rejecting your outbound call likely from Settings: Advanced: Advanced: Settings for Direct SIP Calls: Local SIP domain. Set to your domain name.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    I am using DynDNS.org with several external extension without any problem.
    Don't forget to setup "Direct SIP Calls" field as Ian replied.
