foulad said:which ports i should forward to the server on the router ?
It turns out that the Grandstream profile had the "Accept INVITE from Proxy Only" turned on. This prevented the hand-off of the call to the Android app. Turning this option OFF fixed the problem.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
