Dynamically Created Audio Files not palyed
Discussion in 'CRM / Helpdesk / App Integration' started by linking13, Oct 29, 2013.
  1. linking13
    Nov 14, 2008
    42
    I have followed the article on URL http://www.3cx.com/blog/docs/vad-play-dynamic-files/ to play a dynamically created audio but nothing is played, nor in case of function as explained in http://www.3cx.com/blog/docs/playback-sequence-of-digits-with-3cx-vad/ nor in a more simple expression like
    CONCATENATE('pippo','.wav')
    The audio file is correct and are placed on the path as explained on the attachment
    What is wrong?
  2. linking13
    Nov 14, 2008
    42
    I have partially resolved changung the expression with
    CONCATENATE('Numero',MID(callflow$.Digits,callflow$.Index,1),'.wav')
    but remain a strange problem if this function is nested within many other: if this procedure is under e userinput component nested in a loop and included in a user component the debug show me that all flow is correctely execute but I can't hear nothing and the flow has no problem. Exaclty the same procedure (Cute&Paste) used directly on the main flow (only one loop in my case) works well
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there,
    Please, check this article to enable verbose logs in 3CXIvrServer.log file and send me the contents of that file after a failed call:
    http://www.3cx.com/blog/voip-howto/troubleshooting-vad-applications/
    That way we can check the error that you're experiencing.
    Thanks!
  4. linking13
    Nov 14, 2008
    42
    I'm sorry but I have redesigned the flow and now everything works fine so I can't generate to you a log with the problem
  5. linking13
    Nov 14, 2008
    42
    The problem is returned. This is the part of 3CXIvrServer.log reguarding my call. As you can notice the prompt is corrected added but nothing is played from Ildocidedaleidigitato.wav to Digitiunoperconfermare.wav
    11:24:01.913|8080|VXIMachine.cpp(1072):IvrDll, CallSession::prompts_Play(), Play Queued files
    11:24:05.926|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Digitiorailcodicecdc.wav
    11:24:07.363|10944|VXIMachine.cpp(1072):IvrDll, CallSession::prompts_Play(), Play Queued files
    11:24:10.960|10944|VXIMachine.cpp(1108):IvrDll, CallSession::prompts_Stop(), Stop playback
    11:24:15.983|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Ildocidedaleidigitato.wav
    11:24:16.007|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Numero4.wav
    11:24:16.024|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Numero7.wav
    11:24:16.040|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Numero8.wav
    11:24:16.059|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Numero9.wav
    11:24:16.075|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Numero6.wav
    11:24:16.099|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Digitiunoperconfermare.wav
    11:24:16.162|10944|VXIMachine.cpp(1072):IvrDll, CallSession::prompts_Play(), Play Queued files
    11:24:20.108|10944|VXIMachine.cpp(1108):IvrDll, CallSession::prompts_Stop(), Stop playback
    11:24:20.108|10944|api\VXIpromptImpl.cpp(266):IvrDll, VXIpromptImpl::Impl::Queue(), Warning! Ignoring TTS in (text/plain;charset=wchar_t). Text is 'Sorry, I didn't understand you. '
    11:24:20.108|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Digitiunoperconfermare.wav
    11:24:20.120|10944|VXIMachine.cpp(1072):IvrDll, CallSession::prompts_Play(), Play Queued files
    11:24:27.161|10944|VXIMachine.cpp(1108):IvrDll, CallSession::prompts_Stop(), Stop playback
    11:24:27.179|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\lapreghiamodiattendere.wav
    11:24:27.721|10944|VXIMachine.cpp(806):IvrDll, CallSession::RegisterPrompt(), Added prompt C:\ProgramData\3CX\Data\Http\Interface\ivr\FirmaDocumenti_5\Attenziocodicenoncorretto.wav
    11:24:27.734|10944|VXIMachine.cpp(1072):IvrDll, CallSession::prompts_Play(), Play Queued files
  6. linking13
    Nov 14, 2008
    42
    ADDENDUM: the problem doesn't happen always. Sometimes when I launch the component with a code everything works fine, the next call with the exactly the same code doesn't work
  7. linking13
    Nov 14, 2008
    42
    Finally seems resolved. I have attached 0,5 sec of wav with silence after the loop
  8. VAD_Support
    Aug 6, 2009
    690
    Maybe this article may help you:
    http://www.3cx.com/blog/docs/config-last-message-to-play-on-a-vad-app/
    The last message to play in a VAD application needs to be configured with AllowCutThru = False, so it is played and not buffered.
    Kind regards.
