Dynamics configuration
Discussion in 'Windows' started by dieu2villejuif, Jul 17, 2017.
  1. dieu2villejuif
    Jul 17, 2017
    Hello everyone,
    I recently integrated and deployed the Dynamics CRM plugin in the client. I'm willing to automate the configuration of the plugin to ease the deployment. To do so, I tried to override the %appdata%\3CX Phone for Windows\3CXCRMUser.ini file with the information of my CRM server by executing a logon script.
    My problem is that when the client starts on startup, the plugin doesn't seem to work (it does if I reboot the client, and the configuration is OK too), and when I try to go to Advanced Settings > Integration, nothing happens.
    I wanted to know if I can modify information in the ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\MicrosoftDynamicsCRM\OnPremiseAuthenticationConfigurationControl.cs without any problem?
    Also, will it be possible to change those information in the 3CX management console ?
  2. dieu2villejuif
    Jul 17, 2017
    Found the solution to the problem!
    I was starting 3CX via a batch script, and somehow the "start" command didn't allow the plugin to work.
