Dynamics CRM Activiti On Answer
Discussion in 'CRM / Helpdesk / App Integration' started by Dominik Meier, Apr 6, 2018.
Tags:
  1. Dominik Meier
    Jan 12, 2018
    8
    we use the 3CX Client Plugin for Dynamics CRM.
    The contact folder also opens, but the activity in CRM is not created until the call is ended.
    Is it possible that the activity in the Microsoft CRM system is already created when answering the call.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    897
    69
    Hello @Dominik Meier,
    Unfortunately that's not something you can configure. The call activity is only created when the call ends. If you need such a feature, you would need to change the scripts provided by 3CX, creating a custom plugin.
    Kind regards.
  3. stefanprasch
    Aug 28, 2015
    11
    Hello, unfortunately this is not possible with the solution of 3CX Dynamics CRM. It also cannot be customized because the solution is locked.
    Regards. Stefan
  4. edossantos
    Jun 27, 2007
    897
    69
    We provide the C# code. You can edit this code as you wish and upload your changes as a custom plugin. The solution is NOT locked, you can do what you need with it.
    stefanprasch likes this.
  5. stefanprasch
    Aug 28, 2015
    11
    Hi ernesto thank you for your reply,
    for a normal user (without any developer skills) it´s not easy or possible to do changes. The C# code is not locked you are right, but the solution is managed so i can´t do changes when the original solution is running. so you are right i have to uninstall and change the files and then upload as a own custom plugin/solution.
    best regards from germany
    Stefan Prasch
  6. Faserm
    Apr 4, 2018
    9
    Is modifying the file the only way out?
  7. Dominik Meier
    Jan 12, 2018
    8
    Okay thank you for your answer.
    Can you tell me where to look in the source code?
  8. edossantos
    Jun 27, 2007
    897
    69
    Yes, the only way is modifying the scripts. The scripts are located into a ZIP file in the 3CX server:
    - For Windows: C:\ProgramData\3CX\Instance1\Data\Http\Interface\MyPhone\Integration
    - For Linux: /var/lib/3cxpbx/Instance1/Data/Http/Interface/MyPhone/Integration
    You can unzip the ZIP you need to edit, change the scripts, make another ZIP and upload it as a custom integration.
