Dynamics CRM integration
Discussion in 'CRM / Helpdesk / App Integration' started by chaney, Jan 31, 2018.
  1. chaney
    May 13, 2016
    5
    We are running v15.5 Update 2 on-premise and have an IFD Dynamics 365 deployed. When we enable 3cx it does not error but never screen pops either.
    I have not been able to find any logs on the client to try and investigate further. Any assistance would be appreciated.
    Thanks,
    Chris
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hello @chaney,
    The logs are located in folder "%AppData%\3CXPhone for Windows\Logs". Take a look at them and let us know in case of needing any help.
    Kind regards.
    Ernesto.
