E90
Discussion in '3CX Phone System - General' started by rodneyeid, Aug 11, 2007.
  1. rodneyeid
    Aug 8, 2007
    18
    anyone knows how to configure E90 in order to USE 3cx gateway??
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi rodneyeid,
    Your E90 connect to local LAN or NAT over the Internet? E90 can working fine at LAN. However, it maybe unable to registered to 3CX via NAT over Internet.
    Normally, all the SIP clients will work if all the following fields are correct.
    User Name: XXX
    Password: ***
    Authorization User Name: XXX ( same as user name)
    SIP Server Name: xxx.xxx.xxx.xxx or sip.xxxxxxx.com
    Outbound Sever: xxx.xxx.xxx.xxx or sip.xxxxxxx.com
    STUN Server: stun.3cx.com (disable if the phone in use at LAN)
    Regards,
  3. rodneyeid
    Aug 8, 2007
    18
    i am using nat over the internet!!! how will it work!!??
    but i tried others like truphone, and it it working fine and registered andi did calls! i think there is something we are missing in configuring the 3cx!!!
  4. rodneyeid
    Aug 8, 2007
    18
    + i think it is a setting from the server we should do! cause i checked the truphone settings and they are the same i am putting , so this leaves us with server setup!
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If you using NAT over the Internet. At phone side MUST config the STUN server for that profile. At server side you MUST enable "Bind to Media Server" and "Extension is external".
  6. rodneyeid
    Aug 8, 2007
    18
    still not working
    anything else i could do
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please take a look this post http://www.3cx.com/forums/viewtopic.php?t=1488
