Easier way to change templates
Discussion in 'Ideas' started by ppickens, Oct 26, 2017.
Easier way to change templates 5 5 39votes
5/5, 39 votes
  1. ppickens
    Jun 19, 2013
    25
    11
    Being an admin of 20-30+ installations of 3cx, I and my co-workers have one major issue with upgrading. We are forced to use custom templates for all clients, due to the fact the 3cx base templates are not suitable for most businesses. This isn't too hard to fix on the template side of things, but changing templates for each extension after every upgrade has become a tedious process since the advent of version 15. In version 14 you could select the template from a drop down, click apply or okay and then continue with the rest. Now the process is to delete the template/MAC from the extension, click add, re-enter Mac address, select template, OK, check all other settings (IE phone webpage password) and then click OK. This greatly extends the upgrade time, as it is important to use the new 3cx approve template syntax.
    Is it possible to make this process like v14? Or possibly allow a mass modify via .csv import without having to delete all the extensions. This would make things much easier on the administrative staffing that actively sell and support 3CX.
  2. jvaillancourt
    Oct 19, 2017
    I agree with you. That is one part of the management console that I wish they would redesign.
  3. dkeethler
    Dec 30, 2015
    55
    15
    I definitely don't know why 3CX made this change--it specifically makes things MORE DIFFICULT. Can someone from 3CX comment here?
  4. services5
    Jun 21, 2013
    11
    We also found this , most default template are not for power business or aka power user , we even could not have the correct dialtone with snom phone and this is consider normal ......
    Frederick Marcoux likes this.
  5. Silly English Kniggit
    Sep 13, 2017
    215
    77
    Agreed. This is a lot harder than it needs to be. It's great trying to make 3CX more user friendly, but it would be very helpful if 3CX could remember that their partners often heavily customise to suit end users - and without that customisation, those sales are very hard or impossible to make - 3CX and the partner lose sales.
    futures, curtcar21 and accentlogic like this.
  6. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    Agree, agree, agree.
    Makes it much more work.
  7. f2it
    Apr 15, 2009
  8. yanceyworks
    Mar 11, 2013
    10
  9. dkeethler
    Dec 30, 2015
    55
    15
    Can anyone from 3CX reply to this thread? I opened a ticket with them as to why the process was degraded and the answer I received was essentially "tough luck, go post something in Ideas".
  10. tstrathdee
    Nov 5, 2014
  11. ppickens
    Jun 19, 2013
    25
    11
    Thanks fellow partners for the support on this. It is quite problematic for us.
    3CXDude likes this.
  12. dkeethler
    Dec 30, 2015
    55
    15
    I don't want this thread to die. Still looking for someone from 3CX to comment here.
    3CXDude likes this.
  13. dkeethler
    Dec 30, 2015
    55
    15
    Following up. Waiting on 3CX response.
    accentlogic likes this.
  14. services5
    Jun 21, 2013
    11
    +1 , there is not a single deployement where the default templates are not modified to answer customer's needs , without this not a single 3CX would have been sold from us
    Frederick Marcoux and curtcar21 like this.
  15. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    This is especially an issue for phones behind an SBC. The new features added for phone provisioning each extension help, but they each must be done manually for each extension.
  16. phil@lgmanor.com
    Oct 13, 2016
    25
    +1 - add a HQ location with 20 remote sites as bridges and it gets old.
    +20
  17. brianlgrimm
    Dec 17, 2010
    19
    +1. Very painful to change templates.
  18. curtcar21
    Jul 7, 2016
    14
  19. simply7
    Jan 4, 2016
    38
    17
    Agreed. there needs to be a better way to modify templates en masse. Even though you can export, delete everything, and import. That just does not make sense and is a waste of time, especially when customers don't want to pay for it.
    Oh also can custom template not show up as red under Phones? hard to determine out of date phones and custom template phones.
  20. Joe Bobbitt
    Jan 25, 2018
