Easily Change Forwarding Target Number from Phone
Discussion in 'Ideas' started by rayfield, Nov 10, 2016.
Easily Change Forwarding Target Number from Phone 5 5 3votes
5/5, 3 votes
  1. rayfield
    rayfield New Member
    May 4, 2010
    130
    In 3CX, forwarding of an extension can be enabled and disabled by the extension user, through a button programmed for that function (Forwarding On/Off).
    However, the Forwarding Target Number (the number to which calls are forwarded) must be entered into 3CX through the Management Console.
    In some cases, it is necessary that the Forwarding Target Number be occasionally changed.
    I propose that 3CX support a dial code, whereby an extension user can enter a Forwarding Target Number for that extension 'on-the-fly'. This would allow this Forwarding Target Number to be easily changed whenever necessary, without someone having to go into the 3CX Management Console to do it.
    John Rayfield, Jr.
  2. Gioal
    Nov 9, 2017
    11
    Same here.... Why this is not implemented yet? Every PBX has this feature native.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,496
    67
    I don't understand - in all 3CX clients we can customize forwarding rules, including a target number (be it extension, system extension, generic number); it's not this what we are talking about?
  4. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    782
    134
    It is a fairly straightforward task to build a CFD application that when dialed prompts you for the forwarding number. It could then update your extension settings.
  5. Gioal
    Nov 9, 2017
    11
    No, is about change the destination of your calls from your phone istead of using an app.
    Hummm... can you provide any example? I am not so familiar with CFD. Any demo inside of CFD that can be followed?
  6. voiptoys
    Feb 13, 2013
    782
    134
    Hummmm.... perhaps I should have said straightforward for us. Here is the basic code logic:
    1. Get the extension number that dialed the CFD
    2. Prompt caller for phone number
    3. Verify the correct number of digits
    4. Re-request phone number if failed validation
    5. Call external code component
    6. Code component uses Call Control API to change forwarding rule
    7. Play prompt "extension successfully updated"
    8. Hang up
    There are example projects that come with the CFD for how to request digits and validate, but diving into the Call Control API to update the extension would be a little beyond the scope of the forums.
    You could enhance this further so that if someone called from the outside (not an extension) it could detect that and also request the extension to be updated and request the voicemail PIN for authentication. It's up to you how far you want to take this.
  7. Gioal
    Nov 9, 2017
    11
    Many thanks bro. I will try this and let you know if it works.
  8. voiptoys
    Feb 13, 2013
    782
    134
    You can contact me directly if you need programming assistance.
