Easy conference
jleed
Hey, is there way to make easy conference room, so people just deal:858 and nothing else.
or any idea where conference vxml located, so I can make working conference easier for ppl in my office
You can use the Call Control API for that if you want:
http://www.3cx.com/blog/docs/call-control-api/
But you would have to handle it yourself, there is no support for that API. Anyway the samples are self explanatories, so it's not big deal.
All the VXML files are located into %ProgramData%\3CX\Data\Http\Interface\ivr, but I would not change that because you would lose your changes when applying a service pack for example.
Regards,
making c plugin looks hard to me for now, guess way to go edit vxml and backup for updates.
but I can not find vxml for conference here C:\ProgramData\3CX\RollBack\AppData\Data\Http\Interface\ivr
is it exist for conference rooms?
The folder you need to check is C:\ProgramData\3CX\Data\Http\Interface\ivr (not Rollback\AppData\...).
Anyway, I'm not sure if you're going to be able to do it that way, because there is much code there already compiled to a DLL, so even if you change the sources, the code will run from the DLL. So, give it a try if you want, maybe changing VXML files works, but changes to CS files will not work. I don't know what file you need to change. The clue I can give you is that everything starts from ivr_start.aspx (code behind Default.aspx.cs).
Getting Started - Admin
jaayb512
Get 3CX - Absolutely Free!
3CX
