Easy Speed Dial
Discussion in 'Ideas' started by trenove, Jul 29, 2016.
Easy Speed Dial 5 5 6votes
5/5, 6 votes
  1. trenove
    Apr 15, 2013
    I installed 3cx in a company having an old asterisk, with a speed dial phonebook od over 450 entries.
    I followed this guide to create speed dials in 3cx.
    http://www.3cx.com/blog/voip-howto/spee ... und-rules/.
    The problem is we did this operation for more than 450 times. The person who did this has gone :)
    Now i am asking the ability to
    - ability to import speed dials loading them from a CSV or EXCEL file
    - ability also to export the list
    - ability to order the list aby speed dial
    maybe speed dial should be in a separate management and not in the outbound routes ?
    For example, why not define a "prefix" for speed dial, for example "4"
    Then import the list via csv, and the numbers will be example 300 to call 0123456789
    So when user dial 4300 (4+300) the 3cx will dial 0123456789
    What described is regarding v14, but checking V15, it seems the same. Please do something to let us have a better speed dial system
    Thank you
    Davide
  2. etccomputerland
    Jul 1, 2016
    I second this request. I have just installed a 3CX system with over 100 "speed dial" rules. It would be nice if this could be incorporated into the contact lists as well.
  3. Aytek Aydogan
    Jul 2, 2017
    5
  4. IT_S
    Dec 20, 2017
    18
    Same request.
