Easy way to change ringtones
Discussion in 'Windows' started by agentsmithitaly, Feb 15, 2018.
  1. agentsmithitaly
    Jan 3, 2018
    In our environment there are multiple 3CX clients in the same room all with same ringtone, which may sound confusing when a phone rings.
    I understood changing ringtone involves picking up an audio file, convert it to 16 bit, 8000hz mono WAV file, and replace ringtone.wav under C:\ProgramData\3CXPhone for Windows\PhoneApp\Sounds
    This procedure seems convoluted. Would it be possible to add an option in the Settings where user could select a different ringtone from a dropdown menu with a stock of built-in ringtones, and the ability to upload a custom ringtone in the most common audio formats, with automatic conversion to whatever format is needed?
    Thank you
