Easy way to delete all messages for an extn?
Discussion in '3CX Phone System - General' started by jonh, Jun 23, 2010.
  1. jonh
    Jun 23, 2010
    Is there an easy way, without logging onto the handset itself, to delete all messages for a particular extention?
    Cheers,
    Jon
  2. dab
    dab
    Nov 1, 2009
    67
    I've not tested it, but it should work ...
    Delete *.wav and *.xml files under C:\ProgramData\3CX\Data\Ivr\Voicemail\Extensions\XXX
  3. jonh
    Jun 23, 2010
    Thanks, this appears to have worked a treat!
  4. wzaatar
    Aug 1, 2007
    90
    Tested before and it actually works. You beat me to it. :)
    I actually cleared out all the directory. There should be some counter of messages somewhere there. Don't know how 3CX internally 'counts' the number of messages. Maybe someone from 3CX can answer this question.
