echo and choppy voice
Discussion in '3CX Phone System - General' started by Urbok, Oct 24, 2007.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I'm considering to use standard voip phones because with grandstream gateways ht 386, I've a lot of echo and also seem that the voice quality is very poor...
    with a voip phone the quality it's better?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Some people have been having some problems with Grandstream gateways, choppy sound, poor quality voice... just like you are experiencing...
    I can tell you that Voip has very good quality voice(depending on codec used and avaible bandwith) of corse everything needs a bit of tweaking... maybe thats the problem with your gateway...
    You can always get a better gateway. People been using Patton alot, saying voice quality is very good, i use here a Linksys SPA3102, also works very good...
    Cheers
