Echo in the background when making or recieving skype call
Discussion in '3CX Phone System - General' started by kittinz, Sep 13, 2009.
  1. kittinz
    Sep 13, 2009
    There is an echo when using the gateway to send or receive calls through the gateway.
    I am able to dial out without problems. Takes a moment to connect but otherwise works fine.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,442
    61
    I guess your problem is the same as this one, which can be solved:
    http://www.3cx.com/forums/technical-notes-10528.html#p54038
    Try this to see if it works.
    Regards
    vali
