Echo when call to PSTN line
Discussion in '3CX Phone System - General' started by cbni, Jan 29, 2007.
  1. cbni
    Jan 27, 2007
    12
    hi
    The PBX software works very good, but when I call a pstn line via
    my voip provider the call have a lot of echo on the pstn phone
    I call from the 3cx softwarephone and here is no echo
    my system is beta 4 and it is on a xp pc
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    305
    Have you tried if the echo is present when using a VOIP phone directly. Echo would be down to the VOIP provider or VOIP phone that you are using...
  3. cbni
    Jan 27, 2007
    12
    I have now tried with the new beta 5 but this is the same when I use
    3cx softwarephone but if I use X-Lite softwarephone it work ok
