Edit extension number in v12
Discussion in '3CX Phone System - General' started by mixig, Oct 30, 2013.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    how can we change exstension number on the existing extension? Once we press apply that field is greyed out. Only option i can see is that I need to remove that existing extension and create the new one with the same settings.
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    It does appear that they changed that behavior.. unclear why. Removing and adding a new extension does seem a bit cleaner, though.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Once an extension is created, the extension number is uniquely allocated in the system as a Distinguished number. You cannot edit the extension number after this.
    If you want to edit an extension because you do not like the number any more you have to Delete the extension and create a new one with the number you like or simply create it from the start correctly.
    When you create an email account with gmail, you cannot go and change the email address. It is an integral part of the account. Same thing applies here.
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    OK, the reason I asked this is because that was possible in v11... it is good to know that there are no other options except to delete the current extension.
