Edit mode on Groups level
Discussion in 'Ideas' started by TEIN d.o.o., Jan 18, 2018.
  1. TEIN d.o.o.
    Aug 7, 2008
    You should add an option to edit Out of Office hours per User Groups. If you have for example 70 User Groups (Subsidiaries) and specific office hours for them it is a time consuming & double process to edit all those extensions with specific Office hours. First you have to create a User Groups and then you have to do it all over again for Office hours on extension level.
    3CX is targeting to a large enterprise segment and this is something to be considered ASAP. I suppose is quite easy task for you. Same "bulk edit" mode on Groups as it already is on Extensions level. Or just add Search criteria per Groups on Extensions level. Problem solved.
    Rgds, Greg
