Edit more than one "DID" at same Time in v15
Discussion in 'Ideas' started by Jens Thomas, May 23, 2017.
  1. Jens Thomas
    May 23, 2017
    if you have to manage more than 30-Inbound Rules it needs so much time to make changes.
    For Example to enable "Play holiday prompt when it's a global holiday" for all DIDs, it is necessary to choose entry-by entry.
    In v14 it was possible to select more than one entry to edit.
    Please bring this Feature back...
    Greets
    Jens T.
  2. Dave-TTG
    May 15, 2017
    26
    9
    Hi Jens
    A temporary workaround for this is to export the Inbound rules to CSV, then delete the rules in the 3CX console you want to change, then change the CSV to the new values and re-upload. It will only replace the rules that don't exist (i.e. the ones you deleted)
    Hope this helps
    Dave
    #2 Dave-TTG, May 23, 2017
