Edit phone number in MyPhone doesn't seem to work
jcasares
Whenever I try to edit a number in MyPhone from the phone book I'm presented with the dial dialog and whatever I try just dials the phone instead of saving the edited number. A bug?
Hi, this is not a bug.
When you select on a Phonebook entry and you right click edit number - dial dialog is shown and yes you can call that number or edit that number because it could be busy but still you have only 1 option to call/dial.
If you want to edit number - select phonebook entry and there is an option Edit Phonebook entry.
Then yes you can save that entry.
Ok. Then the menu option could be misinterpreted. Maybe can be renamed to something like "edit and dial number".
Getting Started - Admin
leo13215464
Get 3CX - Absolutely Free!
3CX
