Edit Provisioning Template for 3CX Client
Discussion in 'Ideas' started by narkumas, Nov 3, 2017.
Edit Provisioning Template for 3CX Client 5 5 19votes
5/5, 19 votes
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Hi 3CX Staff,
    I am annoyed about hte fact that I manually have to set the option "replace + by 00" every time a user uses the 3CX Client the first time.
    It is the same with the webclient.
    Since this option is located under "account settings" it should be possible to set it with the management console.
    Any more users annoyed? please vote and reply!
    cheers
    Marius
    3CXDude likes this.
  2. RogerS
    Dec 12, 2017
    13
    10
    You are absolutely right. All 3CX client options should be configurable over the 3CX Management console.
  3. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Thank You for Your support!
  4. PaulD
    Jul 4, 2010
    89
    9
    Agreed
  5. Patrick.Clemens
    May 25, 2018
    9
    I think you can add an outbound rule like:
    Prefix +
    Route Sip Trunk
    Cut 1 - insert 00
    or use the E164 Settings
