Edit the 3CXPhone template
Discussion in 'Ideas' started by gdesnoues, Dec 16, 2015.
  1. gdesnoues
    Dec 16, 2015
    5
    Make possible to change the 3CXPhone template to configure default options same as :
    - sort presence by
    - transfert using Drag and Drop
    - focus
    - video and audio settings
    - chat settings (auto open when new message)
    - default dashboard (User, receptionist or manager)
    - and others .....
    these options are not present on the page "Serveur Mangager > Extension Settings > 3CXPhone"
