Edit who is able to answer calls
Discussion in '3CX Phone System - General' started by runnerpaul, Dec 13, 2013.
  1. runnerpaul
    Nov 22, 2013
    25
    Currently in our ofice if a phone rings anybody else in the office can answer it by pressing *20*. Is is possible to cahnge this so that by pressing *20* people can only answer calls going to those in the same ring group or call queue?
    Cheers
    Paul
  2. way
    way
    Feb 21, 2011
    49
    In Settings-->advanced-->custom parameters there is a parameter called LIMIT_PICKUP_TO_GROUP which I believe is the option you're looking for. Default is 0, setting this to 1 means that extensions can only pick up calls from their ring group.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Or if you dont want do that in custom parameters, you can go: Settings->General-Global options and check "Limit call pickup to call received in their extension group"
  4. runnerpaul
    Nov 22, 2013
    25
    I tried both but when I tested it I got a 40 error on my phone.
  5. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Are you using v11 or v12?
  6. runnerpaul
    Nov 22, 2013
    25
    It's version 11.
  7. way
    way
    Feb 21, 2011
    49
    In addition to creating ring groups, have you created extension groups? This can be done from the extensions tab. I would recommend creating extension groups in a similar fashion to the ring groups' setup.
