editing provisioning templates for Yealinks T26-T28
Discussion in '3CX Phone System - General' started by ostwald, Jun 10, 2015.
  1. ostwald
    Jan 5, 2015
    Hello ,
    we have 100 plus Yealinks T26-T28 and we are in need to edit the templates to change a label , right now after the phone is provisioned it shows the extension number on the screen and we want it to show the Users Name instead , it will be very helpful if someone could provide the steps to change the way , i could follow the steps here http://www.3cx.com/blog/docs/phone-provisioning-templates/ but that doesn't explain how to accomplish the change i want
    thank you for your time in advance
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
    Upgrade to ver 12.5 and make sure the phone are running the latest firmware
    It will show name, in the top right of the screen
