Email Address in Webclient
Discussion in 'Ideas' started by 12329, Jan 25, 2018.
  1. 12329
    Oct 3, 2008
    The user should be able to update their email address in the webclient. Under Settings\General\User Information they can change their Name and mobile number but there is no field to change their email. Currently they have to login to the management console to do that.
