Email Alert when X country called or cost/min more than x $
Discussion in 'Ideas' started by sexy-trousers, Sep 19, 2016.
  1. sexy-trousers
    Feb 12, 2015
    9
    It would be great to be able to get an alert or a report when calls are made to specific countries (or the cost per minute is over a certain amount).
    Although we need to allow calls to some far off and/or expensive countries, often it can be abused by staff or non-staff (i.e. cleaners etc.), it would be nice to be able to be alerted when a call is made to (for argument sake) Nigeria... Either based on a named country list, a cost basis when calls are over a certain price per minute or even "this is the first time a call has been made to this country...
    Thanks, TJ
  2. Anonymous
    Anonymous Guest
    This one can be implemented via the 3CX API if you'd like to go that route.
