Email not Editable
Discussion in '3CX Phone System - General' started by davidsteelerose, Jan 31, 2017.
  1. davidsteelerose
    Apr 6, 2015
    20
    3CX Phone System Pro
    Version 14
    License Perpetual
    Maintenance 07-Dec-2017
    We can not edit the email field of Extensions. Any pointers where to look?
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    182
    15
  3. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,816
    564
    If you are using webmeeting for these extensions then the email field will be greyed out. De-select them from the webmeeting tab and try again
