Email Notification not working for management console
Discussion in '3CX Phone System - General' started by cpontus, Dec 20, 2012.
  1. cpontus
    Feb 17, 2012
    42
    I enabled the Email Notification for 'Log in and Log out of 3CX Management console' but I am not getting anything each time I log in/out of the management site. Can anyone else confirm this? I get alerts for trunk status and emergency numbers just fine. 3CX 11 SP3.
    On a sidenote, thanks to 3CX for finally adding in SSL email server support. No more stupid workarounds!
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    This notification is working only when users with proper access log in and out from management console, not the administrator.
  3. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Yes - I can confirm this ... If you enable an extension to have access via http: into the Management URL - using it's extension number and PIN, then you will see log-on and log-off e-mail messages. There are no messages produced when the administrator log-on is used either via URL or via the 3CX Management app'.
    Bottom line on this one, is if you want to give Management access to somebody else - and you need to log their access - do it using their (or an ...) extension number and PIN.
    best regards
