email notification not working
Discussion in '3CX Phone System - General' started by ikonectu, Jun 18, 2013.
  1. ikonectu
    Mar 26, 2013
    16
    Looking for a little help with email notification. I currently have 3 sites, 2 with commercial / licensed 3cx systems, 1 (mine) with the NFR key.
    I have setup mail server as follows: settings, general, mailserver:
    mail server: smtp.xxxx.com
    reply address: noreply@xxxx.com
    user name for smtp server: noreply@xxxx.com
    password for accessing smtp server: (valid password)
    SSL/TLS is not enabled
    under extensions I input a valid email address and selected "send email notification only"
    I checked the server activity and no indication system tried to send notification. I also checked the windows event viewer, again no indication of email being sent.
    help? What am I doing incorrectly? Is there a option / setting I am missing?
    any help is appreciated.
    gary
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    764
    39
    Hi gary,
    user name for smtp server: must be a valid username. Not noreply@xxxx.com
  3. ikonectu
    Mar 26, 2013
    16
    Thanks Complex1.
    The "xxxx" were just to indicate the FQDN.
    I finally figured it out. I had to go into custom parameters and add the SSL port. I suppose I could have accomplished the same by appending the server name in mail server settings.?
    Thanks again for your reply.
    gary
