Email option with exchnage server
Discussion in 'CRM / Helpdesk / App Integration' started by davidbenwell, May 1, 2012.
  1. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    We have setup a VAD App to send the output of the callers input via email.
    if we set it to use a external mail server "Linux" then all works very well. soon as we try and set it to use an Exchnage 2007 or 2010 it will not send the emails.
    any ideas? we tryed putting the username as DC-(domain)\username but this does not help.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The protocol used is the same (SMTP), so the problem pretty sure is the authentication.
    Try using double slash (\\) because the single slash is a escape character in javascript.
    The error description should be stored in a log file named "Errors_EMailSender.log", located in the deployment folder: C:\ProgramData\3CX\RollBack\AppData\Data\Http\Interface\ivr\YOUR_PROJECT_NAME
    Let me know if this helps you.
  3. davidbenwell
    Apr 27, 2010
    704
    does not show any logs of that name at the location you listed.
  4. VAD_Support
    Aug 6, 2009
    690
    Sorry, the right folder is:
    C:\ProgramData\3CX\Data\Http\Interface\ivr\YOUR_PROJECT_NAME
    Where you need to replace YOUR_PROJECT_NAME with your project name and latest build number.
  5. davidbenwell
    Apr 27, 2010
    704
    I have checked the path but there is not a file of that name. Please can you check the location and file name and confrim?
  6. VAD_Support
    Aug 6, 2009
    690
    If you're having an error with the E-Mail sender component a file with name "Errors_EMailSender.log" should be generated in the project folder (the path is correct).
    But maybe here you're having another error. In that case we should check the 3CXIvrServer.log file located at C:\ProgramData\3CX\Data\Logs\3CXIvrServer.log. Please look at that file and send me what you find.
    Thanks,
  7. tom_ch
    Jul 6, 2011
    69
    I suppose you have to enable the internal mail-relay on your exchange server.
